Im planning on liquid cooling my i7 5820k and my gtx 980 Ti, only problem is my gpu is a EVGA GTX 980 Ti VR eddition. basically it has a hdmi port at the front of the card for easier acess.
Link to card below.
http://au.evga.com/articles/00981/evga-geforce-gtx-980-ti-vr-edition/
Just asking if this will be an issue or if there is a water block that works for this card. primarily looking to use EK parts. thanks for in advance :)
https://linustechtips.com/topic/681056-gpu-water-block-help/
Link to card below.
Have a look here under the video cards, see if yours is listed:
https://www.ekwb.com/configurator/
I cant load the page at work
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/681056-gpu-water-block-help/#findComment-8757822
no its not listed, thats why im trying to find out if its the same as one of the listed types.
https://linustechtips.com/topic/681056-gpu-water-block-help/#findComment-8757826
I would say the block won't fit. Just judging by my last 2 blocks, 970 and 1080, the front sits pretty much flush with the card
Ryzen Ram Guide
https://linustechtips.com/topic/681056-gpu-water-block-help/#findComment-8757830
https://www.scan.co.uk/products/ek-fc-original-csq-high-performance-nickel-plexi-full-cover-water-block-for-ref-design-gtx-titan-x-9
thats a reference block, there's no cut out for the hdmi
I guess you could cool the chip and buy some passive heat sinks for the vram, but you're gonna need good airflow
Ryzen Ram Guide
https://linustechtips.com/topic/681056-gpu-water-block-help/#findComment-8757839
Unless you cut either the water block or HDMI on GPU, you won't find full water block that would fit.
You can use universal GPU water block, but your VRM will be melting.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/681056-gpu-water-block-help/#findComment-8757840
