Building pc
3 hours ago, DivingEagle said:I was just browsing and this one looked great, and wasnt that expensive. Is there a cheaper one with same performance?
Not really. Most of the ones I mentioned are around the same price, and they all give similar performance. You could go with something like the Cryorig M9i which is a smaller height CPU tower which is only $20 USD, it would be a few degrees hottor but price to performance is technically better. I would just stick with the Pure Rock (if you're buying it between $25-35 USD, don't pay more than that), it's a great cooler and it's quite quiet. Not sure how that translates into your currency, just don't overpay. Look at the other coolers I mentioned in the last post and check prices, as long as they aren't drastically different then get the Pure Rock.
