Hi, I'm building my first PC soon, and I wan't to know if these will work together. I know there is PC part picker but I've heard it can mess up,
CPU -
Intel i5 6500 - $205
Graphics card -
EVGA GeForce GTX 1060 3GB - $200
RAM -
8 GB (4GB x2?)- $40
Case -
$30-$50
Motherboard -
Gigabyte LGA1151 Intel H170 Micro ATX DDR4 Motherboard (GA-H170M-D3H) - $90
PSU -
Rosewill 80 PLUS BRONZE Certified Power Supply ATX12V / EPS12V 550 Power Supply Hive-550 - $55
Memory -
1 TB HDD  (WD Caviar Blue)- $50
Toshiba OCZ Trion 150 120GB 2.5" 7mm SATA III Internal Solid State Drive TRN150-25SAT3-120G - $40
Also does anyone have a recommendation on what RAM and case I should get?
Another thing, I plan to use this computer for Cities Skylines, and Space Engineers
Thanks and have a nice day!
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/679882-new-build-i-need-some-help/
PC part picker is just fine.
Ram- Probably something cheap and good like something from corsairs Vengeance line
Case- Corsair spec 02
Power supply: nopeee. Try something from this list in the first 3 tiers at the least.
It looks good. It's still easier to put into pcpartpicker as a preliminary check, and it says most problems down below in the fine print, people just read over it and blame it on pcpartpicker. As for RAM, pretty much anything will work as long as it's DDR4. I would definitely recommend a 2x8GB kit of RAM because those two games are very CPU bound. And yeah, reject that PSU
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Thank you this was very helpful!
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Thank you! Also sorry if this is how you reply to these forums...
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Oh and one more thing. Don't get the 1060 3GB. If you can't afford the 6Gb, get the RX 480 4GB. If you can, the 1060 6GB beats the RX 480 8GB in most games
Hey I have a minor update: I need to have office and word on this computer....
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
