what cooler are you using?
=======================Current Build=======================
Motherboard: ASUS Z170-AR
CPU: i5-6600k @ 4.5Ghz Overclocked
GPU: Gigabyte GTX980 @ 1200 Mhz Oveclocked GPU boost 1400Mhz
Memory: Corsair Dominator 16Gb @ 3200 Mhz
Cooler: NZXT Kraken x61
Storage: Corsair Force GS 128Gb + WD2TB + Seagate 1TB
PSU: Corsair HX650
Lighting: NZXT HUE+ with extension
Display: LG 34' Ultrawide 3440x1440
Peripherals: Razer Blackwidow x Chroma + Razer Firefly + Razer Mamba Chroma
Headphones: Astro A40 + Miniamp
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743824
Most AIOs do not have a variable speed pump.
Forcing them to run at a lower voltage can damage it.
If you hear noise that means there are bubbles going through it and reducing the speed will not help.
Try mounting the radiator vertically at the front of your case with the barbs on the top side.
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743828
1 minute ago, PCNoobie said:
sorry man no experience with that cooler. What header are you plugging the pump into?
PSU: Corsair HX650
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743833
Just now, PCNoobie said:
pump has 3 pin connector, and it's connected to 4 pin water pump on mobo.
Go to the bios and see if you can adjust the voltage on that header, try to increase the voltage since lower voltages can cause gurgling sounds in pumps
PSU: Corsair HX650
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743843
He said he wanted to lower the RPM
but yeah you can adjust it in the bios
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743850
Well it doesn't show up in bios
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743862
What motherboard do you have? You should be able to get some software that can monitor/change fan control
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743883
5 minutes ago, LukaH said:
i had an Enermax Liqmax 240 aio the pump noise was fine at stock speeds. have you had the unit for a long time could be the pump failing?
It's been 2 months. The pump runs quietly on idle(web browsing), but it starts make noise when I play games, and do cpu benchmark.
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743899
Mine is AsUS Z170-A, and I can control fans, but it doesn't show the option for water pump.
What fan header did you plug the cooler into? It should have a name on the motherboard
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743909
8 minutes ago, PCNoobie said:
I plugged it into "w-pump," which is water pump I guess.
You should have gotten a program called Asus ai suite 3 with your motherboard. If not you can download it but it has fan control software in it. I use it on my Asus X99-A
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8743935
43 minutes ago, PCNoobie said:
It worked thanks!
Good to hear :)
https://linustechtips.com/topic/679799-aio-cooler-pump-help/#findComment-8744161
