Why do you need 1300-1500W?
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/679691-queit-power-supply/#findComment-8742779
well be quiet has one afaik... but why would you need one?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/679691-queit-power-supply/#findComment-8742787
Aye, what you gonna power with that? If a lower wattage is possible you have more options to choose from. Corsair RMi linup are very good and silent ones fro example. But think highest is 1000w if correct...
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/679691-queit-power-supply/#findComment-8742827
Just realized that a 1300w PSU at 100% load will produce more heat than a 650w at 100% load, so the 1300w unit will typically have a more powerful fan with a higher startup voltage - making it potentially louder overall when the fan spins up (of course, this also depends on the fan overall profile). If you are only getting a higher wattage unit because you believe that you are getting a quieter unit, just know that may not necessarily be the case. And even if it was, considering how there are quiet low wattage unit such as the Corsair RMx/RMi, EVGA G2/P2, BeQuiet Dark Power Pro 11, Enermax Platimax, etc. that either doesn't have the fan spin up a low loads and / or have a non-aggressive fan profile (thus not spinning up very hard throughout it entire load range), you may be paying large premium on something that wasn't needed.
https://linustechtips.com/topic/679691-queit-power-supply/#findComment-8743016
