PSU power output
Go to solution Solved by ARikozuM,
2 minutes ago, marobrk said:
Actually wait, I lied to you, there is one bequiet dark rock (i think it was dark rock) 1000w psu, but i don't need that much power
be quiet! is better.
Just now, marobrk said:
But my question is, how do I know if the PSU is the actual problem?
Power fluctuations will cause the voltage to drop and take the frequency with it until the computer decides to save itself from undervoltage.
You can also try using display driver uninstaller and then redownloading Nvidia's drivers.
So I replaced my old Sapphire HD 5570 with a GTX 460 and my computer started crashing a lot, I formatted my hard drive and it ran well for a while but it started crashing again. I did some research and found out that my Thermal Master TM-500-PSAP-I3 is not actually outputing 500W, so I'm guessing that's the problem. I can buy a CM GX Lite 750w 80+ bronze PSU, but I'm asking you guys so that I know whether or not I should spend my money on it.
https://linustechtips.com/topic/679544-psu-power-output/
Where do you live? States? EU? Lesser White North AKA Maple Central?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/679544-psu-power-output/#findComment-8741206
What website do you use?
Can you get something from the PSU Whitelist and Tier List? Example: Seasonic S12?
https://linustechtips.com/topic/679544-psu-power-output/#findComment-8741223
I'm not actually buying it from a pc parts shop, a friend of mine got a new one and he's selling it so he's giving me a deal for 2000 MKD which is around 40 USD. Anyway all they serve in my country is Cooler Master PSUs so, that's pretty much my only option here...
https://linustechtips.com/topic/679544-psu-power-output/#findComment-8741234
In that case, I'd go for it.
https://linustechtips.com/topic/679544-psu-power-output/#findComment-8741238
https://linustechtips.com/topic/679544-psu-power-output/#findComment-8741276
