HELP
Go to solution Solved by duckwithanokhat,
Just now, KennDinVen said:
1070 x or z?
Which ever is cheapest, there won't be much performance differences.
3 minutes ago, KennDinVen said:
New to pc building. i want to be able to game in 1440p and i was wondering if it would be worth it to get a MSI GTX 1080 Gaming Z instead of a Gaming X?
You are able to game at 1440p with a gtx 1070 just fine, no need to get a 1080.
EDIT: If you still want a 1080, I would get the cheaper version, there will be very incremental performance boosts between the two.
https://linustechtips.com/topic/679432-help/#findComment-8739942
5 minutes ago, TheRandomness said:
ok thats like a special one, but name any graphics card that they dont have a red and black version for starting from the like 600 series
https://linustechtips.com/topic/679432-help/#findComment-8739985
All armour editions.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/679432-help/#findComment-8739988
but the armour editions arent different cards... i mean like a 970: it might have a white one, and a gold one, but ALSO a red one. every card comes in red
Hmm... how about Palit? EVGA? PNY? All Nvidia reference cards?
USEFUL LINKS:
https://linustechtips.com/topic/679432-help/#findComment-8740034
1 minute ago, Mkander99 said:
oh my god im so glad you are being sarcastic
You're confusing. I just looked at the majority of those vendors cards (the GTX ones, non special editions) in the techpowerup GPU database and saw no red ones.
USEFUL LINKS:
https://linustechtips.com/topic/679432-help/#findComment-8740063
Just now, TheRandomness said:
You're confusing. I just looked at all those vendors cards in the techpowerup GPU database and saw no red ones.
dude please stop, EVERY CARD BY AMD OR NVIDIA WHICH HAS A COOLER MADE BY MSI HAS A VERSION IN RED, but not all versions are red
https://linustechtips.com/topic/679432-help/#findComment-8740071
Well you could've said it at the start. Or phrased your sentence better. Something like:
8 minutes ago, Mkander99 said:
But the armour editions aren't different GPUs. I mean like a 970: there might be one with a white or gold cooler design, but there will be one that has red on it
USEFUL LINKS:
https://linustechtips.com/topic/679432-help/#findComment-8740089
