Case: NZXT. S340 white
Mother board: ASRock z170 Pro4
Keyboard: IBM model M (original cord with no USB adapter)
OS: Windows 10
I found that my front audio panel had stopped working (playback wasn't working but recording was) So after messing around in a few settings and checking Realtek I found it just wasn't seeing anything as plugged in so I shut down my computer and made sure the wires where plugged in fully. They where plugged in fine (from the case to the motherboard port that reads HD Audio). So I started my computer back up and found that my keyboard no longer works(the Num Lock Lights up but no input is detected) and both of recording and playback no longer register on the front but they still work in the back. I plugged in an old usb keyboard and now I'm here. I'm going to go check the bios and update drivers but I figured I would ask too in case there is something I have not thought about yet.
Thank you for any help !
Edit: After restart the keyboard started working again... must have been a fluke (audio is still not working)
https://linustechtips.com/topic/679367-front-audio-panel-and-ps2-stopped-working/
CSGO gamer detected
=======================Current Build=======================
Motherboard: ASUS Z170-AR
CPU: i5-6600k @ 4.5Ghz Overclocked
GPU: Gigabyte GTX980 @ 1200 Mhz Oveclocked GPU boost 1400Mhz
Memory: Corsair Dominator 16Gb @ 3200 Mhz
Cooler: NZXT Kraken x61
Storage: Corsair Force GS 128Gb + WD2TB + Seagate 1TB
PSU: Corsair HX650
Lighting: NZXT HUE+ with extension
Display: LG 34' Ultrawide 3440x1440
Peripherals: Razer Blackwidow x Chroma + Razer Firefly + Razer Mamba Chroma
Headphones: Astro A40 + Miniamp
Maybe the wiring is loose mess around with the front panel wires. Shouldn't be a bios or setting issue if it just suddenly stopped working especially if the I/O on the motherboard is working fine.
PSU: Corsair HX650
