Hello forums,
Recently I bought a new set of headphones which require a spdif out for them to work. As I was trying to get my headphones to produce sound, I realized that there was no light being produced from the motherboard or sound card for the optical cable. I spent hours and hours trying to find out why it won't work, checking my bios, removing and re-installing drivers and searching the web if anyone else has this problem. Nothing, if anyone can help it would be much appreciated.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/67920-spdif-out-not-working/
Hello forums,
have you actived spdif/digital out in the windows sound controls?
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
https://linustechtips.com/topic/67920-spdif-out-not-working/#findComment-930208
Yes, I have
https://linustechtips.com/topic/67920-spdif-out-not-working/#findComment-930219
