As getting my message read in chat is near impossible. I thought this would be the next best place to bring up my point of view.
I had the same issue of audio randomly cutting out for short periods of time. It turned out to be a setting issue in recording devices and having 'Allow applications to take exclusive control of this device' checked under the advanced settings of my Yeti.
Might be related or not just thought I'd share my 2 cents.
https://linustechtips.com/topic/679026-wan-show-audio/
Just now, dexxterlab97 said:
Wait you ask for help in Twitch? What?
The WAN Show is having [audio] issues. @nicklmg
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/679026-wan-show-audio/#findComment-8736379
4 minutes ago, yat0TV said:
Not asking for help, currently the WAN show's mic audio is randomly cutting out but telling a possible fix via twitch chat does nothing I thought I'd bring up my 2 cents on the forums.
The WAN show has never had a stream without some form of issue....I don't expect anything to change.
Due to some voodoo linus magic, the streaming setup doesn't like to work.
@nicklmg
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/679026-wan-show-audio/#findComment-8736395
I wouldn't consider The WAN Show to be The WAN Show UNLESS there was SOME sort of issue.
The audio cut out for literally 1-6 words, each time it happened. Not a big deal IMO.
Trust me: THEY KNOW ALL of the issues, there is just so many of them you can never expect to get them all sorted lololol
Ot amazes me that Linus the PC GOD with his $40,000 network still can't get it working 100%:
Technolgy was made by man, therefore is eternally flawed.
I beatbox
https://linustechtips.com/topic/679026-wan-show-audio/#findComment-8737314
15 hours ago, yat0TV said:
Still an issue, I wonder if they ever saw this post
Actually I just watched the one about Vessle and Vine and Dennis and during all those conversations, which are all I cared about and skipped right to them, the audio never messed up like it did on the episode this topic is talking about.
I beatbox
https://linustechtips.com/topic/679026-wan-show-audio/#findComment-8774157
They restarted the stream after detecting the same problem, and apparently replacing a USB cable solved it (I though I heard it cut once more with the new cable, but can't confirm, and everything went smooth after that).
https://linustechtips.com/topic/679026-wan-show-audio/#findComment-8774387
Why don't they ever test stream before going live? Would solve all issues before hand every time.
I beatbox
https://linustechtips.com/topic/679026-wan-show-audio/#findComment-8780143
They claimed they tested for x minutes (don't remember x, maybe 5 or so), so they were surprised the issue re-appeared.
Although pre-testing could help it start even later :P
https://linustechtips.com/topic/679026-wan-show-audio/#findComment-8780413
  • 2 weeks later...
