So i bought a 32gb Nexus 5x, straight outta the box had a wifi issue.
While starting a download from playstore, first couple of mb would download at max download speed and then decrease to about 10% of max speed.
Problem was solved after turning on Bluetooth.
Even though, updated to nougat and installed the hotfix, issue persisted. Went back to store for DoA, they took the phone and send it to service.
Service did patch it with some update (no clue why that hotfix is not distributed through the software update settings), got my phone back today.
Wifi issue solved, at least the download thingy was. While updating apps from the store, i had the same incident a couple of times(2-3), not a big deal.
I noticed that, when i use instagram or tumblr that are image-based it takes a while to load some images but when bluetooth is on i believe theres no delay. or is it just me?
Is there an app except Speedtest to benchmark phone's wifi speed?
Any suggestions?
https://linustechtips.com/topic/678915-nexus-5x-wifi-issues/
27 minutes ago, wrathoftheturkey said:
Google speed test, it's imbedded into the search engine
Bluetooth being on increasing wifi speed. I'll be damned
Yup read a ton of posts, turning bluetooth on solved many cases.
Can i have a link to that?
https://linustechtips.com/topic/678915-nexus-5x-wifi-issues/#findComment-8735515
