I'm thinking of getting a 650D to do a CPU and GPU loop but I'm not 100% sure what rads I could fit in it. Just by looking at pictures I think I could put a 280 in the top, a 120 in the back and a 200 in the front. Do you guys have any tips/ tricks for water cooling in a 650D or suggestions on what radiators I should get? This is also my first custom water cooling loop so any help is greatly appreciated.
https://linustechtips.com/topic/6784-cooling-in-a-650d/
The tanks on each end of a 200m rad (eg Phobya xtreme 200mm) will probably mean it won't in the front of the 650D. 650D isn't included in the compatibility list for that rad either. I'd go with a thick 240mm or 280mm in the front in push/pull, though you may have to do a bit of case modding. It'll give better performance than the 200mm as 200mm fans don't tend to have the best static pressure.
https://linustechtips.com/topic/6784-cooling-in-a-650d/#findComment-73120
Just measured my 650D and a 200mm rad (the Phobya one anyway, not sure if there's any other 200mm out there) won't fit without a bit of modding. Also see the 1st post here http://forums.overclockers.co.uk/showthread.php?t=18362112
https://linustechtips.com/topic/6784-cooling-in-a-650d/#findComment-73121
