Just now, aSPIRIn4 said:
I already did that.. and nothing.
Don't worry about it. With temps, there is an acceptable range.   Both of these will fall in this range. Besides, those are two totally different gpus, so what exactly are you trying to compare here?
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/678382-gpu-temps/#findComment-8728877
I`m interested in buying one of them but if is going to go up to 80oC , then there`s a problem.
https://linustechtips.com/topic/678382-gpu-temps/#findComment-8728889
I know that gigabyte has the best coolers for Pascal cards. But they tend to have the most coil whine too...
The pascal cards are very low temps, my 1070 asus strix keeps under 60c all the time and its OC'd to 2126 mhz ;) Fan are set to Silent mostly,
https://linustechtips.com/topic/678382-gpu-temps/#findComment-8729215
