Okay so I have about $300 CAD I am willing to spend on a new graphics card and/or a new processor.
I am currently running:
  • AMD A8-6500 APU Quad Core with Radeon HD 8570D (integrated)
  • 8.00 GB of RAM
  • Windows 10 Home 64 bit
  • EVGA 500W 80+ PSU
I know the overall build is pretty bad because I originally bought a pre-built. Looking to get into PC gaming so I'll be open to building a new PC as well.
I'm looking towards the GTX 750Ti, GTX 950/960 or RX 460/470 if I do upgrade to a newer processor.
It would be greatly appreciated if I could have some feedback, suggestions and reccomendations.
https://linustechtips.com/topic/677725-need-help-buildingupgrading-pc/
  • 8.00 GB of RAM
  • EVGA 500W 80+ PSU
I'd recommend selling the A8 and motherboard and getting an i3 and gtx 950 or rx 460. Or a 960/Rx470 if it will fit in your budget once you sell the cpu and board.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
Then he won't have a board...
http://pcpartpicker.com/list/Bcw4gL
THIS is what I mean
Stille (Desktop)
Evoo Gaming 15"
Is there any i3/i5/i7 around the $200 range worth upgrading to? Because right now I'm still on AM2+.
16 minutes ago, LeXerPrime said:
Snip
Definitely take a look at the 1050ti. commin out in a few weeks. probably what you're looking for. pocket the rest of your money and start pooling for cpu upgrade imo
THIS is what I mean
that is USD. he needs CAD. gotta add about 30% to that price tag. plus he will need new DDR4 RAM
http://ca.pcpartpicker.com/list/Bcw4gL
THIS is what I mean
That's $500 CAD. Even with a MAXIMUM $150 increase with the board and chip, it's not enough.
Theres always the used option. I will always recommend used to people who have as little a budget as this. price/performance is WAY better. You could get an i5 combo with RAM and a mobo for $150 and then something like a used R9 280X/380
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Maybe this, still an upgrade
CPU: AMD FX-4300 3.8GHz Quad-Core Processor  ($94.99 @ Newegg Canada)
Motherboard: MSI 760GM-P23 (FX) Micro ATX AM3+ Motherboard  ($61.10 @ shopRBC)
Total: $156.09
Generated by PCPartPicker 2016-10-18 23:56 EDT-0400
1 minute ago, dexxterlab97 said:
If hes seriously considering simultaneous upgrade, this is about the price you're looking at: http://ca.pcpartpicker.com/list/tfD9KZ
if he could get a great deal on reselling his components and stretch his budget a bit, then maybe its feesable.... but its just not realistic imo. 300 is a hard limit, he should focus on a dedicated GPU for now, as that is going to be a pretty significant performance boost on its own.
except 150 usd for 1050ti is more like 200 cad
4 minutes ago, dexxterlab97 said:
OP here, if it is seriously not worth it to upgrade, I might as well build a new PC. In that case I can afford 600-800 CAD.
Here is an old build I made a while back, though the cpu seems a bit of a poor choice for the price.
http://ca.pcpartpicker.com/user/LexerPrime/saved/rFQtt6
Just now, dexxterlab97 said:
reuglar no titan 1050 then. maybe
saw an NCIX video today... they said 109 and 139, based on an Nvidia announcement. But lets be real, with how GPU sales have been recently, they're probably all going to be well over 200 CAD rofl.
2 minutes ago, Zyndo said:
oh i heard the price was going to be $139 USD.... but whatever, he probably wouldn't buy the cheapest of the cheap anyway. 180 or 200.... still way over budget.
Nonetheless, thanks for all the tips guys. I'll keep an eye on the release of the 1050ti
fair warning... that build is 600 bucks without accounting for GPU or PSU price ;P
However if you recycle a few components from your older build, then a new build may not be a horrible idea.
http://ca.pcpartpicker.com/list/Zk8DwV
that is 600 bucks, and is pretty upgrade friendly. If you're looking to be somewhat serious about PC gaming and want some excellent graphics and framerates, you may want to consider going the route of a gtx 1060 6GB, but that is going to add about 100 bucks to this cost. Although depending on the games you're running and the monitor you're using a 1050ti may be just fine.
Other than that you recycle the HDD, PSU, and case from your current system (I'm assuming that is an EVGA 500B). you get an SSD for much faster OS navigation and boot up times (as well as space for a couple of games for faster loading screens). You may consider buying a more pricey motherboard if this one doesn't have features you want, as this motherboard/socket is going to have a lot of potential upgrades for you in the future (you will have all the other i5's and i7's of skylake and kaby lake to choose from when you decide to upgrade, and if you get a Z170 board now you can even choose from the K series chips as well and get into OCing, but that is totally optional)
but if i had 600-800 CAD to spend on a gaming rig, this is what I would be considering.
