they'd be working against each other to a degree, meaning lost performance.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/677605-fan-on-radiators/#findComment-8720832
6 minutes ago, natsuu said:
would it be better or worse if, suppose we have a radaitor that has 3 fans on the radaitor, what if we had 1 pulling air in and 2 sucking out or vise versa, like the picture
It's usually not a good idea since it tends to recirculate the air between the fans, unless you have a baffle separating the two sections. As for push or pull the performance is basically the same between the setups with push and pull being marginally better by a few degrees at best.
https://linustechtips.com/topic/677605-fan-on-radiators/#findComment-8720847
just go with all fans facing one direction. there's really no reason to not do so.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/677605-fan-on-radiators/#findComment-8720848
1 hour ago, EminentSun said:
For most cases which don't release air directly out, but have some sort of cover over the fans (and even to a lesser extent with more open cases) the radiator would be pulling in air it had just heated, severely hampering cooling performance.
so should i use push or pull? and could i clean the radiator with water like just rinse it in the sink and wait for it to dry, sorry new to water cooling but good in general pc
https://linustechtips.com/topic/677605-fan-on-radiators/#findComment-8720958
Either Push or Pull will work it just depends on the setup you have and orientation, pull is popular though as it does make cleaning the rads slightly easier since you have direct access to the fins of the rad.
https://linustechtips.com/topic/677605-fan-on-radiators/#findComment-8720980
