PCPartPicker part list: http://pcpartpicker.com/list/RVbMFd
Price breakdown by merchant: http://pcpartpicker.com/list/RVbMFd/by_merchant/
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($439.98 @ Amazon)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($119.97 @ Amazon)
Motherboard: MSI X99A GAMING PRO CARBON ATX LGA2011-3 Motherboard  ($279.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($78.99 @ Newegg)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($314.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 1080 8GB FTW Gaming ACX 3.0 Video Card  ($684.98 @ Newegg)
Case: Phanteks Enthoo Evolv ATX Glass ATX Mid Tower Case  ($189.99 @ Amazon)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($92.99 @ Amazon)
Other: CableMod E-Series ModFlex Full Cable Kit for EVGA  G2, P2 & T2 - Black
Total: $2321.87
Generated by PCPartPicker 2016-10-18 18:19 EDT-0400
The quicker the reply, the better. I play on buying parts today. My main questions - is motherboard overpriced, I honestly don't give a flying shit about lights. What would be the best replacement for the motherboard? Should I go with a 5820k instead of 6800k? Also, I just want a quiet PC build, so what is recommended PSU? And is this the best version of GPU? Thanks for your help :)
https://linustechtips.com/topic/677597-thoughts-on-build/
You got a super sweet build there. But you are missing a hard drive. And the Kraken X62 is out
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/677597-thoughts-on-build/#findComment-8720722
Thanks man! Had no idea the X62 was out, thanks for telling me.
32 minutes ago, dexxterlab97 said:
For x99 it's not really overkill as things are expensive. What is that build for? Gaming only then stick with 6700k. PSU is fine but for a single card it is bit too much. No HDD?
I'm going to be doing some video editing and photoshop, so might as well have the extra cores. I have to 500GB 850 evos, so i'm going to be using that for overflow. And I might add in a second card later. Thanks :)
32 minutes ago, tlink said:
the amazon OEM 64 bit windows 10 home is overpriced. get this one: https://www.kinguin.net/category/22175/windows-10-home-oem-key/
a better gpu would be the titan x pascall
Definitely going to buy it off kinguin. And I agree, but that GPU is not necessary for what i'm going to be doing.
14 minutes ago, wrathoftheturkey said:
Not really, not for an X99 MoBo. You could find something cheaper that would do fine, but not by much.
That's a really damn good PSU
Honestly they should perform about the same if I recall correctly.
If you care about customer support, then yes. EVGA is supposed to be amazing. The cooler? There are probably a little better, but not by much.
Alright cool. Thanks for answering my questions!
https://linustechtips.com/topic/677597-thoughts-on-build/#findComment-8720906
