Tried all sorts of things. Mempost clearing cmos different arrays of the ram sticks... any ideas or is my ram kit just dead?
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
https://linustechtips.com/topic/677278-need-help-bf-code-asus-x-99a/
Also to mention it has been running on this kit for the last 6-7 months so not sure if the whole kit just died or what
1 minute ago, done12many2 said:
How did you come to the determination that it was your RAM?
I haven't just yet. Everything I see keeps pointing to ram as the code will go to 53 if I swap the slots
Did go back to stock clocks/configuration while you were testing the sticks?
I can't get it to post to even go in bios. Trying the cmos one more time
Nada... odd
Are you saying that you can't even clear CMOS?
Pulled the battery for 10
mins as well as tried to hit the bios flashback on the back of the board. I'll look around some more
Tried all 8 ram slots. Seeing a lot of users evga Asus etc having issues with ram or so it seems... odd this happened this far down the road
Just now, done12many2 said:
Were you able to get CMOS cleared?
Negative
5 minutes ago, done12many2 said:
So what were you doing when this happened for the first time?
Uh I was resetting the thing actually lol. I'll try this cmos again
There's little to know chance that you lost all sticks at the same time.  It would also be unlikely that the IMC on your chip would just quit without signs of heading south. Your problem is more than likely with the motherboard (BIOS, configuration settings, or hardware).
Idk would be nice to test some other ram... may have to buy some cheap crap off cl
I'd flash that BIOS with the latest 3402 update before throwing money at it.  You can use BIOS flashback to do it.
I'll give it a shot if the cmos doesn't work this time.
35 minutes ago, done12many2 said:
BIOS Flashback doesn't require memory or a CPU installed, so if you have issues with flashing the BIOS update, you've narrowed it down to your board.
Think this is my last time owning a extreme edition board and CPU... constant issues with this Fucking thing.
10 minutes ago, done12many2 said:
You ain't ready for varsity team yet bud.  xD
Did you flash the BIOS?
The fucking thing won't even flash it. Like I'm to the point of throwing this fucking thing out the window. Issues upon issues with this damn thing is driving me fucking insane
Yeah, so you more than likely have something wrong with the BIOS on your motherboard.  The fact that you experienced this right in the middle of a reset makes the likelihood of the BIOS being the issue even greater.
Rule out the fact that your motherboard isn't getting sufficient power from the PSU by trying another PSU.  If that's not it, it definitely the board and you'll need to RMA it.
Yeah, so you more than likely have something wrong with the BIOS on your motherboard.  The fact that you experienced this right in the middle of a reset makes the likelihood of the BIOS being in the issue even greater.
This would make the third board in this damn thing. Like what am I doing wrong I don't get it.....
