right, im planning to liquid cool my pc which severely limits my storage in terms of 3.5" drives DUE TO having a front rad (40mm).
according to corsair website each drive cage thing can have 3 drives, ill only have 1 drive cage
i was think 2x2tb WD black drives in raid 0 or 3x2TB wd black
1x m.2 950pro or 960 evo (512gb) as boot drive
and for back up of the whole computer im thinking of getting a 4 bay NAS
i download alot of 1080p content, FLACS/high quality music, 1080 recording game play, game mods
what would be my choices.
i also would have 3 x 2.5" drive bays spare but i probably wont fill these
i have 1tb in my laptop which isnt enough for my needs with (788 out of 931gb) used and ive wiped everything once and ive had the laptop a year.
many thanks
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/676911-storage-config-help/
Well, if you get the NAS it'll help for sure... all the gameplay/1080/flac etc can be stored on the NAS (just make sure you also get a backup drive too in case of NAS/disk failure, don't bother with raid on the NAS IMO as it's not a backup solution. The stuff that's stored on the NAS can be streamed to your devices when you want to access it, and also bypass the PC/laptop when storing it so you don't have to move it  eg when downloading set the NAS as the "TO" drive/folder. That's how I have mine set up and it works perfectly, I stream my BD rips (usually around 35-50GB) from my NAS no problem to my gigabit wired equipment like my pc/shield tv box, but not sure of my wireless devices as I haven't tried it TBH.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/676911-storage-config-help/#findComment-8712466
i was thinking raid 0 in my pc, raid 1 in the nas, i would prefer to store most things on my pc, and use the NAS purely for back up
https://linustechtips.com/topic/676911-storage-config-help/#findComment-8712469
Ahh ok, yeah that'd work... I just prefer to not store stuff on my PC as it gets tiring to copy stuff across etc when I re-install. Storing on the NAS works for most files as they are mostly low bitrates and streaming them is no problem. But yes, storing them on PC and using a NAS for backup would be OK, just seems redundant in a way to use a NAS like that, you might as well just get a WD mycloud or even just USB 3.0 storage drive TBH.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/676911-storage-config-help/#findComment-8712474
i was thinking of imaging or automatically backing up (tbh idk what or how it works) weekly e.g every sunday.
I would probably put the movies on the nas, not so much the music
im looking at this NAS
http://www.ebuyer.com/668560-qnap-ts-431-4-bay-desktop-nas-enclosure-ts-431
https://linustechtips.com/topic/676911-storage-config-help/#findComment-8712488
I haven't used that NAS before, but Qnap are OK from what I have read. If that's the way you want to go, then that's cool, I use Freefilesync for my backups, it's a great program and is free too :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/676911-storage-config-help/#findComment-8712588
ok, thanks for your help
https://linustechtips.com/topic/676911-storage-config-help/#findComment-8712658
No worries... hope it all goes well for you :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/676911-storage-config-help/#findComment-8712662
ill be sure to post it here :P
https://linustechtips.com/topic/676911-storage-config-help/#findComment-8712689
