Every day this week, I have been plagued by these random shutdowns that turn into reboot loops. Can someone help me?
Also, sometimes it will display a BSOD that says "system expemtion error" and "netio.sys failed".
EDIT: On reboot, the computer will sometimes have the American Megatrends POST logo that says "overclocking failed, please setup your BIOS", even though I use an i3-6300 (Gave the 6600k to a friend) and has reset the BIOS after changing it.
Specs are in the signiture, but I'll put it here as well:
i3-6300
GPU: GTX 1060 Asus Strix
MoBo: Asus ROG Hero Alpha
PSU: EVGA P2 650W
Storage: SanDisk Ultra II 480GB
RAM: G.Skill TridentZ 16GB 2x8
pls help
i5-8600K -  Asus Strix Z370E - Asus GTX 1060 Strix - EVGA 650W P2 - Samsung 970 Pro 500GB - G.Skill TridentZ 16GB
https://linustechtips.com/topic/676779-exccesive-random-shutdowns-help-please/
It wouldn't be... that the i3 is struggling very hard to work with the 1060?
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
2 minutes ago, 79 Potatoes said:
If you're using the battery method with the cord plugged in then it does nothing
What do you mean?
1 minute ago, I_IHaveNoLife_l said:
What do you mean?
In most mbs the way to reset Bios settings is by
1. Clear CMOS jumper
Or
2. Remove and put back in the mb battery. This one needs to be done with the psu power cord unplugged because otherwise data would be kept
This is a signature.
i3-6300
PSU: EVGA P2 650W
pls help
What does event viewer say?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
Or
My motherboard has a CMOS reset botton on the I/O, cleared it 5 times already.
How do I access event viewer?
You click on it?!?!  Its a huge utility that you should familiarize yourself with.
