Need help looking at my build.
Go to solution Solved by The_Stig,
2 minutes ago, BaconRace said:
I like your thinking but I actually can't afford an extra 700 dollars. Might save up but I don't want to wait for it anymore.
Here, 1080 SLI. Cheaper motherboard, yet still E-ATX and very high quality. Extremely high quality PSU (OEM is SuperFlower). Dual EVGA 1080s. As for case fans, I would go with either Noctua's industrial line (Very quiet, very powerful) or, if you don't like the brown, Be Quiet!s SilentWings 3 are an excellent choice.
PCPartPicker part list: http://pcpartpicker.com/list/BGkK7h
Price breakdown by merchant: http://pcpartpicker.com/list/BGkK7h/by_merchant/
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($428.99 @ SuperBiiz)
CPU Cooler: Corsair H115i 104.7 CFM Liquid CPU Cooler  ($110.04 @ Newegg)
Motherboard: EVGA X99 FTW K EATX LGA2011-3 Motherboard  ($252.98 @ Newegg)
Memory: G.Skill TridentZ Series 32GB (4 x 8GB) DDR4-3200 Memory  ($249.99 @ Newegg)
Storage: Crucial MX300 1.1TB 2.5" Solid State Drive  ($236.99 @ SuperBiiz)
Storage: Western Digital WD Black 4TB 3.5" 7200RPM Internal Hard Drive  ($175.81 @ Amazon)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card (2-Way SLI)  ($644.99 @ B&H)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ Newegg)
Case Fan: Corsair Air Series AF140 Quiet Edition 67.8 CFM  140mm Fan  ($17.88 @ OutletPC)
Case Fan: Noctua NF-F12 industrialPPC-3000 PWM 109.9 CFM  120mm Fan  ($22.38 @ OutletPC)
Case Fan: Corsair ML120 Pro 75.0 CFM  120mm Fan  ($24.99 @ Newegg)
Case Fan: be quiet! SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan  ($19.90 @ Newegg)
Total: $2962.30
Generated by PCPartPicker 2016-10-16 08:42 EDT-0400
Hey.
I am building a new setup and I am wondering if all the parts are compatible: http://pcpartpicker.com/list/Wh3Qyf I know they fit together but what I am wondering is do I have enough headers for my fans? I plan on using the Phanteks Enthoo Evolv TG but it wasn't on pcpartpicker.
Is everything compatible or am I wrong?
Thank you in advance for taking your time.
https://linustechtips.com/topic/676458-need-help-looking-at-my-build/
What are you doing with it that requires 2 1tb SSDs? Why do you have a 500$ motherboard when you use basically none of the features? Unless your planning on doing video editing and upgrading to 4 way SLI in the future, this build is far off the peak price/performance.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
seems to be ok, good choice on the mobo.
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
I only ment to add one. My bad. I plan on doing video editing,photo editing and special effects(adobe programs) Price is no problem for me since I have the cash to splash on it since I have been saving up for quite some time and want to "futureproof" in a sense.
13 minutes ago, BaconRace said:
Hey.
Are you alright with taking the cage off?
2 minutes ago, Xreldo said:
I am not experienced with builds over $2000 but I would suggest a 1080 SLI if you can afford it.
Total: $2962.30
Total: $2962.30
I think I will be going with this. I will be going with the Noctua fans since I can't see them in the front anyways. I will be going  with FTW when it comes to the gpu's for the rgb lightning. Thanks for the help.
Cheaper 32GB TridentZ's. Like, a lot cheaper.
Memory: G.Skill TridentZ Series 32GB (4 x 8GB) DDR4-3200 Memory  ($174.99 @ Newegg)
*Has 16 CAS latency instead of 14, but the differences are negligible.
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
