Hi,
I am a student and want to build my first computer for 3D modeling. Mainly for solidworks and inventor and NOT for gaming. budget less than 2k.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($324.95 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Asus Z170-DELUXE ATX LGA1151 Motherboard  ($252.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($66.54 @ NCIX US)
Storage: Sandisk Z400s 256GB M.2-2280 Solid State Drive  ($78.95 @ Amazon)
Video Card: Asus GeForce GTX 1060 6GB 6GB Dual Video Card  ($277.99 @ SuperBiiz)
Case: Cooler Master MasterCase Maker 5 ATX Mid Tower Case  ($169.99 @ B&H)
Power Supply: Cooler Master 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($113.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Pro Full 32/64-bit  ($199.99 @ B&H)
Total: $1576.80
Generated by PCPartPicker 2016-10-16 04:28 EDT-0400
I know quadro will be better for modeling softwares, but for now i not doing extremely heavy stuff.
Any advice is welcome.
And any advice to take note when buillding.
https://linustechtips.com/topic/676381-help-build-a-computer-for-3d-modeling/
nope,not really.gpu's are not different from geforce gpu's,only difference are the drivers and maybe some higher quality stuff on the pcb
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
worth the extra dollars
psu is the heart , if it blows then chances are mobo and/or card fried
so better getting quality eg...EVGA SuperNOVA 750 P2 or the 650w one
just for peace of mind
http://www.tomshardware.com/reviews/best-psus,4229.html
as for cases check out the fractal design cases , well better looking if you like sleek
eg Fractal Design Define R4 Black Window Silent ATX Midtower Computer Case
with the money u save on case goes to psu
This is a better system with $50 more. It has a 6 core and GTX 1070, which, even though you aren't gaming it seems a waste not to go for at that price.
I am going to assume you will need the Pro full version of windows, however, you could get a lisence from kinguin for much cheaper.
I also changed your case and PSU, I don't know if you like the s340, but its a nice little case for the money.
Also, are not going to need a larger storage drive? How about adding a 4tb hdd?
6700k|Hyper 212 EVO|Asus Z170 Deluxe|GTX970 STRIX|16gb 2400mhz Teamgroup memory|Samsung 950 PRO+ 2TB Seagate HDD| CM Realpower M1000|H440
Take a look at my flickr?:  https://www.flickr.com/photos/150012948@N06/
4 hours ago, john917 said:
Hi,
Total: $1576.80
Have you considered X99 for the extra cpu cores ? Also you only need a 550W power supply. Something like the Corsair RMx or EVGA G2 etc would be better.
