4 minutes ago, solarwinggx said:
I bought a temperature sensor for my loop (XSPC g1/4 thread sensor)
Im not sure which way it is supposed to be plugged into the motherboard.
Im also not sure which temperature reading it is supposed to be in HW monitor.
Please help this noob :)
dont they have a display attached?
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/676197-loop-temperature-sensor/#findComment-8705059
It will need a display or reader to show the temps unless your motherboard has a built in 2 pin temp probe point.
https://linustechtips.com/topic/676197-loop-temperature-sensor/#findComment-8705092
You don't plug those into the motherboard. You're supposed to get a gauge/controller device. Something like Aerocool Touch 1000 (pretty crap but cheap and easy to use and install). If you want something really high end and are comfortable with tinkering and programming, look into the Aquaero 5 LT.
https://linustechtips.com/topic/676197-loop-temperature-sensor/#findComment-8705127
16 minutes ago, solarwinggx said:
my motherboard does have a 2pin temp probe point.
but i dont know which way im supposed to plug it in.
The probe doesn't have polarity so it will work either way it's plugged in just make sure that 10K based thermistors as that is the usual standard on temp probes or it may give some funny readings.
https://linustechtips.com/topic/676197-loop-temperature-sensor/#findComment-8706289
According to my mobo manual, the name of the 2 pin header is T_sensor
but I cant find it using HWmonitor or Hwinfo
update: The sensor works inside bios and is under the name T_Sensor. Ive tried disabling it, but still cannot get it to show up in HWmonitor or HWinfo
https://linustechtips.com/topic/676197-loop-temperature-sensor/#findComment-8709050
It depends on what your doing with the sensor but in most cases it won't show up on certain programs I use an external probe and it only shows up on the motherboard manufacture's software or BIOS for fan control.
https://linustechtips.com/topic/676197-loop-temperature-sensor/#findComment-8709286
I have an Asus z170-pro, could you happen to know if this motherboard is known for being unable to display it's T_sensor via software and not bios?
https://linustechtips.com/topic/676197-loop-temperature-sensor/#findComment-8710026
It will show up on AI suite, for mine I have the Z97-pro which never showed up on any other third party software that I know of.
https://linustechtips.com/topic/676197-loop-temperature-sensor/#findComment-8710040
