I've posted this here because the threads I've made on the obsforum have all remained stagnant and lifeless for months now. Hoping Ltt can offer help.
To cut a long story short, I play on a 144hz monitor and record at 60fps. However, when my monitor is set to 144hz, the video I record stutters. If I set my monitor to 60hz, the problem is gone. Recording at 120fps changes nothing. Mirillis Action also mimics this behavior. Setting the monitor to anything above 60hz brings this problem.
Nothing.
https://linustechtips.com/topic/675703-obs-144hz-stuttering/
Have you tried using ShadowPlay? Just assuming you're using Nvidia cards if you're playing 4K at 144Hz... :P
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
https://linustechtips.com/topic/675703-obs-144hz-stuttering/#findComment-8700163
OBS is better and more customizable.
ShadowPlay is good if you just dont want to tinker around.
For OP:
sorry IDK.
https://linustechtips.com/topic/675703-obs-144hz-stuttering/#findComment-8700175
Sounds like a software problem. New recording software or just set it to refresh to 60Hz like everyone else.
My Build:https://linustechtips.com/main/topic/795406-mini-itx-build/   PSU TIER LIST
"The difference between genius and stupidity is that genius has it's limits." - Albert Einstein
"If my doctor told me I had only six minutes to live, I wouldn't brood. I'd type a little faster." - Issac Asimov
"Headward, free now to rise." - Principal Vagina
https://linustechtips.com/topic/675703-obs-144hz-stuttering/#findComment-8700203
Oh I'm at 1080p. Don't mind the 4k res, I was trying something. I'll try shadowplay. Here's actually what's happening. The 60hz was recorded on an older laptop, but it still outputted 60fps quite a bit of the time. Left is 144 (buggy trail), right is 60. (not buggy trail)
Nothing.
https://linustechtips.com/topic/675703-obs-144hz-stuttering/#findComment-8700205
1 minute ago, Orangeator said:
4k @144Hz What kind of sorcery is this? I didn't think that was a thing yet...
Yes people always want bigger numbers even when it doesn't make any difference.
https://linustechtips.com/topic/675703-obs-144hz-stuttering/#findComment-8700213
For OP:
sorry IDK.
I know, I use OBS Studio and I wouldn't trade it for anything else, but since it wasn't working properly ShadowPlay might be worth a try.
https://linustechtips.com/topic/675703-obs-144hz-stuttering/#findComment-8700220
1 minute ago, LoGiCalDrm said:
Are you recording to SSD or HDD? The drive might not be fast enough for you recording at 60fps.
WD Blue 1Tb. I'm assuming it's quick enough since the example was recorded on a 5400rpm drive from 3 years ago.
Nothing.
https://linustechtips.com/topic/675703-obs-144hz-stuttering/#findComment-8702189
OK. Have you tried 30fps while having 144Hz.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/675703-obs-144hz-stuttering/#findComment-8702192
