1 minute ago, Dawson Wehage said:
As in, corrupted
Low level formatting will take care of that. In fact, a regular format will do the same thing.
The only thing a format won't fix is mechanical/electrical gremlins.
Well I am only just seeing if it needs a low level format, I'm not 100% sure that its a mechanical problem, it's a SSD. It gets stuck at the boot screen even when your doing Windows Installs.
lttstore.com
Try to set the SATA controller to IDE mode in the BIOS and see if it boots. If it does come back here with MB and SSD model numbers.
My Build:https://linustechtips.com/main/topic/795406-mini-itx-build/   PSU TIER LIST
"The difference between genius and stupidity is that genius has it's limits." - Albert Einstein
"If my doctor told me I had only six minutes to live, I wouldn't brood. I'd type a little faster." - Issac Asimov
"Headward, free now to rise." - Principal Vagina
