cable
Go to solution Solved by minibois,
In theory, the displayport to HDMI will likely look better, because the signal doesn't have to be converted from digital to analog. In practice, it will barely make a difference.
The DVI to VGA adapter is a lot cheaper though. A solution inbetween those is going to be DVI to HDMI, that's digital to digital, pretty cheap and it's just good overall.
(Also, if you're gonna do DVI to VGA, make sure it's a DVI-I (sometimes called DVI-A) port and not DVI-D)
11 minutes ago, Towsif Rahman said:
Which one will give me more performance and less effort to the GPU with two other HDMI port
1) display port to HDMI adapter (DP on the GPU)
2) DVI to vga adapter (DVI on the GPU)
I used both, and the colour spectrum is better in a DP adapter one.
May the force be with you - Yoda
https://linustechtips.com/topic/675531-cable/#findComment-8697917
https://linustechtips.com/topic/675531-cable/#findComment-8697920
