2 minutes ago, Anglogang said:
Is this a good idea? My idle temps are only about 60 degrees (and this is during the cooler fall months). My stock fan brook and I do not have the money to buy a new one
Don't you have a case fan or something? Macgaiver it to blow some air into the heatsink, it's at least better than nothing.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
1 minute ago, Anglogang said:
My case did not come with fans
Strip one away from another PC, then. I'm sure you have a friend that would be willing to lend you a fan...
At any rate, you'll be fine so long as you don't let temps go up.
I don't know much about cpu temps but I somtimes measure it while I play and it reaches about 90 on Crysis 3
Don't let it get that high. Plain and simple. You can use notepad or perhaps surf the web, but do NOT game on that thing without a fan.
6 minutes ago, fpo said:
keep the heat sink attatched
Do this. See if you can find any fan off another computer to ghetto rig something up (duct tape and zip ties bro)
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
8 minutes ago, fpo said:
I mean.. it might be safe if you only use notepad, and keep the heat sink attatched. Like passive cooling. My 390 does that until heavy duty gaming, and many old GPU used to passively cool only.
nothing is safe. why notepad? there are bunch of other programs when windows start and more heavy than notepad
Can I attach a small metal bowl of some sort, fill it with coolant and but a lid on it?
At least one case fan in the front as an intake would help cool your PC considerably. As for the bowl, lol no. that would leak everywhere. Did the stock heatsink break also? or just the fan
what area do you live. see if you can get someone to sell you a cpu cooler that fits for a few $
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
I am very poor, i NEED this pc for my survival and i do not want to buy a fan for my cpu, are there any FREE ways to cool my cpu? what if i take it out of the case and just put the motherboard on a cardboard box like they do for test benches?
Do you have, like, a table fan or something?
Do you know SOMEONE that has a PC? Doesn't need to be good, you just need to know a person that has a PC.
This could work if you can place it near a fan. Basically you need airflow. If there's no decent airflow source in your home and you can't/won't acquire a fan and can't/won't leave the PC off to preserve its life, be prepared for it to live a much shorter life than it otherwise would.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
can i leave it near an open window?
As long as you don't have any tech savvy criminal birds in your area, and temps don't hit 90 while gaming, probably.
3 minutes ago, dexxterlab97 said:
No.
Umm, does saying "tech savvy criminal birds" summon you or?
17 minutes ago, Anglogang said:
i have some hard acrylic tubing, is it possible to solder or use some high strength glue to attach them, and fill them up with coolant?
Liquid cooling works well because of the flow of the liquid. Having coolant just sit there isn't what you want.
17 minutes ago, dexxterlab97 said:
What is wrong with cute little Blue Naped Monarch
Absolutely nothing, it's the right color
