Hello there, I added a second samsung 950 pro 512GB to my PC yesterday. Everything works fine, the drive is working and all, but now when I start my PC it does something new. Let me explain: it starts for like 1 second, then stops, then restarts by itself 1 second later and its working fine after that. It doesn't do it if I restart while being in windows, so it's on first startup only.
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/675277-pc-startup-issue/
1 hour ago, daniielrp said:
Hhhmm odd. Is the correct SSD still selected as primary boot drive in bios?
might be the issue, il restart now to check.
https://linustechtips.com/topic/675277-pc-startup-issue/#findComment-8695773
The 950 pro with windows is the boot device so thats not the issue
https://linustechtips.com/topic/675277-pc-startup-issue/#findComment-8695806
I would attempt a BIOS / CMOS reset. It's possible the motherboard decided to change something on you when you added the drive.
There's no reason it should have, but you know technology: autoconfiguration thinks it knows whats best.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/675277-pc-startup-issue/#findComment-8695936
I just realized this issue doesn't happend when the PC gets started, but when the PC gets started after regainning power. Like if lets say the PC is on then I shut it down then wait 15 mins and start it again it doesn't get the issue, but if I shut it down, then remove the powercord then plug it back in, the issue comes back.
https://linustechtips.com/topic/675277-pc-startup-issue/#findComment-8696033
