So the Sony a6000 has a video bitrate of 50mbp/s, and I'm not 100% sure what SD cards are fast enough to handle it. The Sandisk Ultra has a minimum write speed of 10MB/s, which theoretically is 80mbp/s and therefore should work, but I just want to make sure this would work
Thank you!
https://linustechtips.com/topic/675231-sd-card-speed/
Thank you!
The Sandisk card you should be sufficient for the A6000.  Or just buy one of the cards listed under the accessories section of the A6000 on B&H.  You've already spent a few hundred on a camera, what's another $10 or so on buying a slightly more expensive memory card?
This one is just a few $$$ more than the Sandisk Ultra you linked.
https://www.bhphotovideo.com/c/product/1275611-REG/sandisk_sdsdxve_064g_gncin_extreme_sdhc_64gb.html/pageID/accessory
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
https://linustechtips.com/topic/675231-sd-card-speed/#findComment-8694757
thank you! I'm gonna be getting a couple of them, so the $10 adds up a little bit
https://linustechtips.com/topic/675231-sd-card-speed/#findComment-8695088
