Hey!
I have a Zalman Z11 Plus with water cooling holes in the back, is it possible to detach the pipes from the radiator in an all in one water cooling unit to run it through the holes in the case? Cheapo unit like a Corsair Hydro 120? (https://www.amazon.com/Corsair-Hydro-Performance-Liquid-Cooler/dp/B00FZHWFEW/ref=sr_1_1?ie=UTF8&qid=1476269181&sr=8-1&keywords=watercooling&th=1)
Samuel Edwards
- IT Engineer and Media Producer -
Religious theology diploma and over half a dozen certificates in Advanced Computing and IT.
Current Project:   Mineral Oil Cooled PC
Just trying to be friendly and help where I can. Have yourself a great day!
Use @SamuelJE for friendly tech help :)
Main PC - "The Genesis"
Mobo   -   Gigabyte GA-H170-Gaming 3
CPU     -   intel i5-6600K 4Ghz on water
GPU     -   MSI GTX970 "Red Dragon"
Case    -   Zalman Z11 Plus (Custom RGB Obviously, It's 2017 bro...)
OSD     -   Crucial 275GB M.2 SSD
SSD     -   Crucial 250GB SATA SSD
HDD    -    4TB WD Green x 2
Disp     -   LG ultra wide Gaming Monitor
Secondary PC - "Jonah"   (Mineral oil PC)
Mobo   -   Gigabyte GA-B250-DH1
CPU     -   intel i5-7500 Under Oil
GPU     -   Nvidia GTX 660 (Favorite and first ever GPU)
Case    -   A Fish Tank W/ Custom Engineered Mounting System (Custom RGB Obviously, It's 2017 bro...)
HDD    -    2TB WD Green
https://linustechtips.com/topic/674604-noob-needs-help/
1 minute ago, Puhtutz said:
Guess so, but don't see any good in doing so.
Just for ascetic tidiness, so pipes do detach and reattach easily? Or is it a getto thing?
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/674604-noob-needs-help/#findComment-8687858
No. Not without high risk of leaks and such.
Some "AIO" units however have the ability to do this so you can expand your loop.
Swiftech H220 would be my recommendation if you want to do this.
If not, your only option is custom loop.
Hope this helps :)
https://linustechtips.com/topic/674604-noob-needs-help/#findComment-8687860
It may work, but there is an increased risk of leaks and fluid loss leading to it breaking.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/674604-noob-needs-help/#findComment-8687863
Hope this helps :)
My good sir, that is fantastic! Thank you very much. I don't suppose you know if one that is 120mm and has the same detachment feature?
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/674604-noob-needs-help/#findComment-8687864
Fractal Design Kelvin T12 :)
https://linustechtips.com/topic/674604-noob-needs-help/#findComment-8687972
