16 minutes ago, BloodyWaters said:
I have a intel i5-2320, which is 3ghz, but even under 100% turbo boost to 3.3 doesn't activate. In the bios, turbo boost is on, so I don't know what's wrong.
CHeck your "power management" or whatever the option is called in windows control panel. You might have power saving mode activated.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
Can you take a print of HWMonitor under load, please? Let us see what's going on inside that PC of yours.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Turbo works in stages. If all four cores are under heavy load, then turbo is at its lowest, then there is a soured set for two and three cores. The speed they advertise as up to is for a single core being used heavily. Run cincebench single thread and you'll see.
The only other reason is not hitting max is because it is running too hot.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
Is 140 farenhight hot for a chip on full load?
It shouldn't be. Did you run cinebench single threaded yet? You on high performance power plan?
My rig:
