Hello all,
I'm ordering an entire system tomorrow and have decided to go with the FX-8320. However I'm not sure on this motherboards compatibility because of people mentioning flashing bios' which I don't want to do. Ideally, I want to just slap it on the motherboard and it works.
Heres the motherboard in question  Gigabyte GA-970A-DS3P Socket AM3+ 7.1 Channel Audio ATX Motherboard
Basically - Will the FX8320 work out of the box in this motherboard.
Thanks in advance!
https://linustechtips.com/topic/67459-fx-8320-compatibility-help-please/
Don't worry about it, it will be fine.
It should yes. Worst case scenario, the good guys on here could guide you through the process, it's very simple and only takes a couple of minutes ;)
CPU Overclocking Database <------- Over 275 submissions, and over 40,000 views!
GPU Overclocking Database
it should work!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
If you get the black board (latest revision) it's 100% compatible, if you get the blue board (one of the older revisions) there is a chance a BIOS update will be needed but this is very unlikely.
As TechFan@ic said, you will want to make sure you get the Gigabyte GA-970A-DS3P which is ready to go without needing a BIOS update. Avoid getting the Gigabyte GA-970A-DS3 (without the P) which you will need to update with the new BIOS.
Intel Core i7-8700K @ 4.8GHz | Corsair H110i GTX | EVGA RTX 2080 XC | Asus ROG Maximus XI | Intel M.2 nVME SSD 1TB | Samsung 850 EVO 2X2TB | 32GB G.SKILL Trident Z 3200MHz CL14 RAM | EVGA SuperNova GS 1050W | Kept cool & quiet in a Fractal Design Define R5 Window with all Noctua fans
It should work fine.
AMD FX-8320 @ 4.3 ghz | Corsair H60 (Push/Pull)|  8GB Kingston Hyper X DDR3 1.6 ghz | Sapphire HD 7870 Oc'd | Biostar TA970 MOBO OCZ 750w  PSU | 2TB HDD + 120gb Kingston V300 SSD| Coolermaster CM Storm Enforcer Case | SoundBlaster Audigy SE  Windows 7        "I am a leaf on the wind, watch me..."   "You know nothing Jon Snauhh" "Take the risk of thinking for yourself, much more happiness, truth, beauty, and wisdom will come to you that way."
/Steam Profile/Folding@home stats/TekSyndicate Fourms/  \m/  RIP David Gold (1980-2011) \m/ RIP Peter Steele (1962-2010) \m/ RIP Chuck Schuldiner (1967-2001) \m/ RIP Dio (1942-2010) \m/ RIP Cliff Burton (1962-1986) \m/ RIP Dime (1966-2004)
