Noctua fans are about as good as they come. My friends on his radiators are impressively quiet even at max RPM.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/674472-silent-fans/#findComment-8686242
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/674472-silent-fans/#findComment-8686252
1 hour ago, Thread212 said:
Well mostly Noctua fans are well used for that kind of thing.
But there's also other manufacturer.
Like cooler master and corsair.
So take ur pick.
-Cooler master silencio 120mm
-Corsair Ml series <- So overpriced
-Be quiet Shadow wing/Pure wing
-Thermaltake riing
Can vouch for Thermaltake riings, have the rgb's and feel it's a very minimal compromise of performance for appearance, if you're into that sort of thing anyway. Not the best price/performance ratio so the appearance would likely have to entice you to be worth it. If appearance isn't a concern, Noctua vomits are good performers.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/674472-silent-fans/#findComment-8686545
7 hours ago, Ctown0812 said:
Can't go wrong with Corsair SP120's quiet edition, or performance edition if you prefer. They cost about 25 USD on new egg for a twin pack depending on what you get, so they won't break the bank.  The PWM versions are around 30 USD for the twin pack.
SP120 QE's are alright. PE's are loud and not worth getting. The PWM versions aren't as smooth sounding.
Some good options are
Magma Advance: http://pcpartpicker.com/product/kFBv6h/enermax-case-fan-ucmaa12a
Hyperborea: http://pcpartpicker.com/product/qKvRsY/rosewill-case-fan-rocf11004
SW3: http://pcpartpicker.com/product/WrvZxr/be-quiet-bl066-505-cfm-120mm-fan-bl066
NF-F12: http://pcpartpicker.com/product/b2vRsY/noctua-case-fan-nff12pwm
NB-eLoop: http://pcpartpicker.com/product/zvphP6/noiseblocker-case-fan-itrb12ps
https://linustechtips.com/topic/674472-silent-fans/#findComment-8690394
I use the ones that came with my NZXT 340, I even got an extra fan from NZXT, I've tried some Corsair SP140's with red LED's, but I could not get over how rough they sounded compared to the whisper quiet NZXT's.
PC - NZXT H510 Elite, Ryzen 5600, 16GB DDR3200 2x8GB, EVGA 3070 FTW3 Ultra, Asus VG278HQ 165hz,
Mac - 1.4ghz i5, 4GB DDR3 1600mhz, Intel HD 5000.  x2
Endlessly wishing for a BBQ in space.
https://linustechtips.com/topic/674472-silent-fans/#findComment-8718732
