What fan do you have, which motherboard and header is the fan plugged into, and what fan settings are you using?
https://linustechtips.com/topic/674199-cpu-fan/#findComment-8683891
CPU - i7-4790
Motherboard - Asus z97-A
Using the stock fan and its on Smart mode, auto in bios and how do you check which header it is plugged into?
https://linustechtips.com/topic/674199-cpu-fan/#findComment-8686699
47 minutes ago, Thenothing said:
CPU - i7-4790
The fan header will have labels like cpu_fan or cha_fan, etc.
The stock fan should be plugged into the cpu_fan header. Have you tried setting the fan to the Quiet or Silent preset?
https://linustechtips.com/topic/674199-cpu-fan/#findComment-8686918
oh ive set it on standard and the cpu fan is plugged into the cpu_fan header
https://linustechtips.com/topic/674199-cpu-fan/#findComment-8688644
Turn it to the Silent or Quiet mode preset and that should lower your fan noise.
https://linustechtips.com/topic/674199-cpu-fan/#findComment-8689282
