3 minutes ago, ANONYMOUS_POTATO said:
I been using this usb flash drive for a while now. It was originally 16 GB (14.5 gb on computer) and it is showing up as a 1 gb (990 mb on computer). Can anyone explain what could of happened and if possible how to fix it.
It sill has the files in the trash. You need to delete them for good
Check out my gear here --> https://kit.com/JWMFilms
https://linustechtips.com/topic/674150-help-with-usb-drive/#findComment-8682800
did you by mistake format with only 1 Gb on it? not sure how to help mate
Main Rig
CPU: Core i5 6600k (not OCed) - GPU: Sapphire Nitro+ RX480 8GB - MB: Asrock Z170 Pro 4 - CPU Cooler: Deepcool Gammaxx 200T -
RAM: Corsair Vengeance Blue LED 16GB - PSU: CoolerMaster V850 - CASE: CoolerMaster MasterCase Pro 5 - Monitor: Viewsonic XG2401
DRIVES: 275GB Crucial MX300 Boot SSD - 525GB Crucial MX300 Games library SSD - 2TB Seagate Barracuda Other stuff
Laptop - Toshiba Satellite L850
CPU: Core i7 3630QM - GPU: AMD Radeon 7670M - RAM: 12GB mix and match
DRIVES: 500GB Samsung EVO Boot SSD - 500GB Seagate HDD
Periphs
Mouse: G303 + G240 MP - KB: G710+ - HS: G933 - Speakers: Logitech Z213 and Creative SBS380
https://linustechtips.com/topic/674150-help-with-usb-drive/#findComment-8682888
7 minutes ago, ANONYMOUS_POTATO said:
No. I just dont know what happened.
Nothing that I can help you with mate sorry
Main Rig
Periphs
https://linustechtips.com/topic/674150-help-with-usb-drive/#findComment-8682971
Just now, ANONYMOUS_POTATO said:
ok but thanks for trying.
no worries
Main Rig
Periphs
https://linustechtips.com/topic/674150-help-with-usb-drive/#findComment-8682975
