Sudden FPS Drop
Solved by belfouf,
21 minutes ago, Simply.RCC said:I just think if i change to a bigger monitor my card wont be virtually scalling to a 1080p resolution.which it naturally supports?
About dota2, at my current setting w/ the 1080p resolution i think i got 40-58 ish fps and w/o dropping to 10.. its not yet confirmed to be ok cause i just tested it with AI or bots and not with real ingame
if your screen is not 1080p, yes you can change it but no, the video card will not work less
dota 2 : you're not alone : https://steamcommunity.com/app/570/discussions/0/492378806375807169/
if 1920x1080 is worse than 1600x900, then lower configuration. If min config at 1080 is still worse, go back to 1600x900, but keep in mind this issue is only with dota 2
