Hey guys, I'm planning on buying a AIO cooler for my I7-6700K build in the Mastercase 5 build, But im wondering what AIO cooler should i buy?
NZXT Kraken x61 in the front.
NZXT Kraken x41 on the top
or
Cooler Master Nepton 240M on the top
It's my first time working with AIO coolers, And im wondering whats the best option for me. Budget is no point on those three.
I want to know which you choose in these category's.
Performance:
Looks:
Software:
Sound:
https://linustechtips.com/topic/673398-mastercase-5-pro-radiator-placement/
or
Performance:
Looks:
Software:
Sound:
The Nepton 240M is one of the quietest AIOs out there and offers pretty good performance from what I've heard.
The black fans give it an edge in terms of looks IMO, unfortunately I don't know about the software, or if it even has any beyond the motherboard BIOS.
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
59 minutes ago, Exposal said:
I have fans mounted inside the bracket pulling through the radiator instead of pushing, the 240 should fit without issue if that's what your doing. Dunno if it'll fit inside the bracket with fans pushing though.
Can you take a pic?
