Because your monitor cannot display the pixels , so it limits you to the resolution of the display.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/673300-resolution-problem/#findComment-8674059
1 minute ago, Anir said:
I m currently limited to 1280*720 while my monitor can support a maximum of 1366*768.
Try changing the aspect ratio to that instead of 16:9
https://linustechtips.com/topic/673300-resolution-problem/#findComment-8674079
