I've brought an new pc yesterday,
Configuration
processor: Core i7 6700k
motherboard: Asus Z170 pro gaming
Ram: 2x8gb
HDD: 1TB Western Digital
SSD: Corseir 120gb
Operating system : win 7
my problem is after installing the windows 7 it took around 40Gb storage from ssd... even though all the files inside my drive shows total 16GB...
where did all the 24gb go!
do I have a Problem in my new ssd or what? I'm a bit confused... don't know much about ssd though :(
https://linustechtips.com/topic/673125-ssd-issue-need-help/
If you right click the drive on explorer what does it show?
https://linustechtips.com/topic/673125-ssd-issue-need-help/#findComment-8672484
prolly have hibernation still enabled (hiberfil.sys).
cmd prompt (admin run)
command prompt type (less quotes)
'powercfg -h off'
review this to optimize OS on SSD: http://www.overclock.net/t/1156654/seans-windows-7-install-optimization-guide-for-ssds-hdds/0_30#post_15523325
https://linustechtips.com/topic/673125-ssd-issue-need-help/#findComment-8672496
