Temps cryorig r1 ultimate
Solved by WoodenMarker,
Depending on the fan speeds and other variables, you should get 55-65c at load with stock speeds.
Most people can get 4.5ghz or more with such a beefy cooler but your mileage may vary depending on your chip and how comfortable you are with pushing voltages and temps.
rayu ·
Ordinaal ·
Posted in New Builds and Planning2 -
sumgreenday ·
Posted in Displays7 -
5
1
avg boywithuke fan ·
Posted in Troubleshooting0 -
11
