2 minutes ago, GameRage said:
so i have a corsair strafe (NON-RGB) and i was wondering where can i find non-rgb lighting profiles i really hate the fact that no one is making red lighting profiles
and btw i can't do shit with the CUE software
Why can't you do shit with CUE? It's not difficult, you just need to learn.
Other systems I've built:
https://linustechtips.com/topic/672787-corsair-strafe-help/#findComment-8669089
Just now, slomo007 said:
Getting a product with customization and then not using it because "you're too lazy to use the software" is a bad idea to be honest. Just google some tutorials and you'll learn how to do it.
yeah i guess, but the reason is that one time i saw a tutorial on how to use the CUE software properly and i think it was a corsair staff(or some shit like that) and he didn't explain anything apart from how to apply pre-made lighting effects like the ripple or the visor and after that i didn't bother
https://linustechtips.com/topic/672787-corsair-strafe-help/#findComment-8669112
Try to find another tutorial but if that doesn't work for you, just play around in the software.
https://linustechtips.com/topic/672787-corsair-strafe-help/#findComment-8669119
