Wake on lan issue
Go to solution Solved by mattk,
Wake on LAN and Booting to your network is different.
If you want to enable wake on lan try this.
Quote
Try to do this (in your BIOS)
Go to Power section -> APM -> set "ErP ready" to "Off"
Then you will see more options
Set "Power on by PME Device" to "On
https://superuser.com/questions/339416/wol-for-asus-m5a97-built-in-realtek-network-adapter
You don't want to set to boot to your network, out it back to your Hard Drive.
Hello
im trying to set up a wake on lan on to turn on my pc with my mobile.I run win10 with a M5A97 R2 motherboard. i already enable magic packege on my net adaptor, modify the bios to allow power with PICe and when i  change the bios to Lan boot first priority to boot, my mobile turn the pc on but windows dosent start. any help?
https://linustechtips.com/topic/672405-wake-on-lan-issue/
13 minutes ago, Nachip said:
Hello
SSetting LAN as your boot drive, will say for example, boot from the NAS you ahve plugged into your ethernet port.
SSet yur normal drive as the boot driv,e but just enable wake from lan
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/672405-wake-on-lan-issue/#findComment-8665406
Quote
https://linustechtips.com/topic/672405-wake-on-lan-issue/#findComment-8665486
I already tryed that, i change the boot back to the drive btw
https://linustechtips.com/topic/672405-wake-on-lan-issue/#findComment-8665515
