Strix 1070 Overclocking Issues
Go to solution Solved by done12many2,
20 minutes ago, PixelBeaver said:
Hi everyone,
I've owned my Asus Strix GTX 1070 OC Edition for a few months now, but still have yet to figure out this issue. I love overclocking graphics cards, and even pushed my previous GTX 750 Ti to >960 performance. However, for some reason I am unable to overclock my current 1070 past +60MHz on the clock speed and +60MHz on the memory speed in MSI Afterburner. I looked at some other people's overclocks, and they were all in the range of +200 +700 offset. Any suggesstions or help is appreciated!
EDIT: To be more specific, anything higher than +75MHz crashes the GPU driver immediately whenever I start a game, benchmark, etc.
Motherboard: Asus 970 Pro Gaming/Aura
CPU: AMD FX-9370
This is a great example of why you should use clock speed instead of offset amounts such as +40, +200 and so on when discussing overclocks.  Each card is different and comes with a different factory overclock so +40 on your card may result in a completely different clock speed than another card.  By the way, nobody has a 700+ offset regardless of how good there Pascal card is, unless you're talking about memory, which is a completely different thing.
Hi everyone,
CPU: AMD FX-9370
https://linustechtips.com/topic/672344-strix-1070-overclocking-issues/
Probably because your GPU is already Overclocked. I would go up to 40 mhz to be safe.
http://pcpartpicker.com/list/Mf3Zcc My build
R.I.P Donny- Got banned. We will always remember your spamming of "Cancerbooks"
iPhones are like 1 ply toliet paper with a logo slapped on them and years old hardware in them- A Wise Man
Hi everyone,
CPU: AMD FX-9370
+200 BTW is kind of a huge oc, as the strix oc already come @ 1860 ish , that wud put it @ 2060 ish, wich is possible, ive seen it on youtube, but might not be every card silicone, and that might give a tiny 1-5% gain, so who cares....
You should enjoy what you have ;)
