Seeking a replacement external hard drive
Solved by dlf,
I'm thinking one these in a 2 or 3 TB variety. If one of my other externals goes I need some place to keep the data that's on that, don't I?
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136749
http://www.newegg.com/Product/Product.aspx?Item=N82E16822178110
http://www.newegg.com/Product/Product.aspx?Item=N82E16822178117
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236138
