Water cooling reservoir ?
Go to solution Solved by xgn,
If you can fill/bleed it yes.
25 minutes ago, Cla55ifi3xd said:
Could a coil of tubeing act as a reservoir?
It is possible to have a loop without a reservoir but filling and bleeding the loop would be a bit of a trick
