So im doing my first pc build :) And iv checked all my parts for compatibility. (however i couldnt use pc part picker, for some reason my storage device wasnt on there and there was two of the same motherboard...weird) but before i go and purchase everything... I would just like to run the components by you guys. Considering you guys have more experience than me about this stuff :) . any recommendations you have for diffrent parts or my build  you can also post here and i will respect them.
Anyway on to the components
Asus a68hm-k fm2+ amd a68h fch motherboard
I bundled this with the AMD Athlon x4 860k quad core processer
My case is a diy solo-T1-R black case. Nothing fancy but it should hold up especially for the price
A 400watt psu from evga. (keep in mind this is a value build, im not slapping in any titan x's or sli. The most ill put in here is a gtx 950)
G.skills ripjaws ram ddr3 8gb 4x2 sticks(again i dont need anything fancy just enough to do what im doing)
And a silicon power slim s55 ssd 120gb. (i know i know, why not a mechanical drive?. In the past iv had very bad experiences of hdd's failing and i dont want my main drive to be mechanical. At some point ill get a bigger hdd for secondary storage) and yes im aware that this ssd is slow, its value after all, but it should still be marginally faster than a 7200rpm hdd so im sticking with it.
And that is my build any questions,recomendations,or issues with my build i will be happy to adjust or fix.
Thx :)
https://linustechtips.com/topic/672039-first-build/
Thx :)
Your battery is much too low for my liking, you must charge your phone.
https://linustechtips.com/topic/672039-first-build/#findComment-8661788
Thx :)
Switch the S55 for the SP550, the 860k for the 880k or the 845. What GPU?
https://linustechtips.com/topic/672039-first-build/#findComment-8661805
1 minute ago, Lumen15 said:
I was just saying that i got a small psu because i dont plan to put any huge gpu in it. I was just saying what i might put in it
Better quality one at the least. And you don't have a GPU of anykind. As of now, everything would just be a glorified paper weight.
https://linustechtips.com/topic/672039-first-build/#findComment-8661823
As he/she/it has said above, the PSU you bought is of very poor quality as it can explode under load. I would suggest spending $15 extra can buying this. http://slickdeals.net/f/9163635-550-watt-seasonic-g-series-80-plus-gold-certified-semi-modular-power-supply-ssr-550rm-for-44-99-ar-free-shipping-newegg-com
Also, you don't have a GPU, though if you're not gaming, this will be fine. Add a 750Ti from eBay for $50 dollars if you want to play games in the future.
i5-8600K -  Asus Strix Z370E - Asus GTX 1060 Strix - EVGA 650W P2 - Samsung 970 Pro 500GB - G.Skill TridentZ 16GB
https://linustechtips.com/topic/672039-first-build/#findComment-8661923
