Not sure what the problem is, there just PSU cables for Molex, the fan cable goes into the fan header on your motherboard.
Main Rig: Intel Core i7 4790k, R9 280x, EVGA 500 watt 80puls bronze, 32GB Ram HyperX120GB Kingston SSD, 1tb WD Blue, Asus sabertooth Z97, Aerocool A800
Router: Pentium G3220, 8GB Ram, No idea what board,250 Watt PSU, 320gb Seagate Drive
Personal Devices: OnePlus3, Kindle Fire HDX
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661503
What motherboard do you have and does it have an open fan header?
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661504
3 minutes ago, Shroom said:
It's an MSI motherboard I believe.
Your graphics card is from Msi and your motherboard is from Gigabyte.
Please tell us the model name. It should be on the board.
What other fans do you have and which headers are they powered off of?
Take your time when taking photos. They're not helpful when blurry.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661542
I believe the model name is HT3.0 DDR3. I have 3 case fans and one cpu cooler I believe. My other fans were powered off the second picture I showed.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661604
That's not it.
It's looks like a GA-970A-DS3P. The model name should be under the second pcie slot right underneath the graphics card.
If that's the case, you should be plugging the noctua fan into the cpu_fan header since it's the only one that supports pwm.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661658
1 minute ago, WoodenMarker said:
That's not it.
The header is already taken by the cpu.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661669
3 minutes ago, WoodenMarker said:
That's not it.
Also, looks like there's only one but I have two fans :(.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661676
If that's the case, you should probably get a splitter to run off of the cpu_fan header.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661677
Just now, Shroom said:
Ok, how am I going to do that if I need to plugin the cpu cooler and two fans?
There are 3 way splitters.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661690
Could you possibly link me one?
Also, thanks so much for the help.
Where are you shopping/located?
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661704
Ontario, Canada.
This would work: http://www.newegg.ca/Product/Product.aspx?Item=N82E16812423163&cm_re=pwm_splitter-_-12-423-163-_-Product
Btw, there's an edit button--no need to make another post.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661773
I need a 3 pin.
What for?
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661783
My fan headers are only 3.
You should be powering 3pin fans off of the sys_fan headers which provide dc.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661802
Sorry for asking so many questions, but I really want this to work.
The sys_fan is already taken so do you know a fan splitter for that? Thanks so much for the helo.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661826
This is why I asked earlier what fans you currently have and which headers they were running off of.
If you could get back to that question, that would make it easier to help you out. :)
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661829
My one corsair fan is plugged into the sys_fan and my two old case fans were plugged into the PCB if that makes any sense?
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661844
Are you referring to the one corsair case fan in the photo? What are your case fans? They have model names. Not sure what you mean by the pcb.
https://linustechtips.com/topic/672024-fan-case-problem/#findComment-8661848
