Laptop Hard Drive Current?
Go to solution Solved by APasz,
Brand and RPM don't matter. Try to stick to that 700mA if possible but it ultimately isn't a problem as the power delivery system of the laptop has to meet sata standards.
So I'm looking around to be able to find a replacement for my dead laptop hard drive and as I'm looking around, I see laptop hard drives with varying current. The hard drive that was in the laptop is a 700mA but when i look on Ebay, I find laptop hard drives that are 800mA. Such as this one on Ebay: http://m.ebay.com/itm/HGST-500GB-7200RPM-SATA-6Gbs-Hard-Drive-2-5-Inch-/232103667059?hash=item360a74e573%3Ag%3A0TgAAOSwYIxX3ehG&_trkparms=pageci%3A7f41a8da-8ab2-11e6-8b83-005056b688cb%7Cparentrq%3A930ea2fb1570a2a597d125dfffff3ab5%7Ciid%3A2. Is there anything else I should make sure to check when replacing a hard rive besides making sure to get the right size hard drive and the connection?20161004_230907.jpg
https://linustechtips.com/topic/671286-laptop-hard-drive-current/
Well I didn't think the current mattered too much. I just figured the hard drive would just use more current as it needed it. I was actually going to sell this laptop because I got a new one. I've heard a lot of good things about Western Digital drives.
Personally if you are going to sell your laptop I would invest as little as possible in it because you will not recover the cost of the drive. It is hard to get what it is worth anymore from anyone on a laptop. I would suggest that you get something comparable to what you had in it as far as size and speed. If you want the exact same drive you can get it for under $35 new here: LINK
I would suggest something with a little better review  and a better warranty like this: LINK
Bottom line they are about the same price and it is your money. You are going to busy enough installing the operating system into the new drive anyway.
Good luck!
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
That was my thought. I was going to find something close to what I had originally instead of throwing an ssd or a 1Tb into it. Unless if I manage to find one that is ridiculously cheap. Is the type of connection and hard drive size the only I really need to check to replace a laptop hard drive?
Sometimes laptops will uses non standard connectors and so you must get a drive with the same connector which could prove difficult.
The software size of the HDD has no impact on installation but the physical height is something to look out for.
-アパゾ
Well it has the typical sata laptop connector, so finding another one with it wouldn't be that difficult. I didn't think about hard drive thickness though. All the laptop hard drives I've seen look like they're pretty much the same thickness though.
I did some looking around and I found that it looks like that hard drives at 5400rpm, regardless of being sata II or sata III, are at 700mA and hard drives are at 800mA with 7200rpm for HGST hard drives specifically, which makes sense. I know that both of the connections and speeds are compatible with the laptop if you happen to look at the HP spare number. Looking around at other hard drive brands, I see that some currents range from 450mA to 1.1A. I'm not sure if it would still make a difference if I put a Western Digital or Seagate, etc. in the laptop instead.
