Speaker mod help
Solved by Electronics Wizardy,
Run a serprate cable.
Those + and - leads are for audio, so it varies in voltage and is AC.
Voltage wise, it depends on the volume, and a a normal listening is around 1-5V and max volume is around 50v depending on the amp.
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
play_circle_filled
Latest From ShortCircuit:
