Ok at this point I have a lenovo y50-70touch (2014 model) I am looking for a new laptop, becuase I am trying to get some new games and I do not think my laptop will be able to run it at 1080p 60fps. Can some one do me a huge favor and find a laptop that has similar specs to these
 CPU: 6700HQ 2.6 or better
 GPU: Idk a gpu that can play on high and at 60fps or better, idk if the 980m's can do that but 1060 would be better (Atleast 3GB of vram)
Hard drive: HAS TO BE ATLEAST 1TB hydrib or 1TB + 128 or more GB or ssd
Memory: 8 or more GB of ram
Display: 1080p 60hz or better, if you can find a 4k one makes sure it has a 1060 with 6GB of vram. Has to have a backlit keyboard, with either red or multiple colors that can be changed, (but it does not matter overly too much)
Others: Good speakers, webcam does not matter a couple USB ports atleast 1 HDMI and a USB C so I can plug a external graphics card in. Weight does not matter.
Thanks
https://linustechtips.com/topic/670752-i-need-help/
Locked, all the threads you created were about this exact subject, I suggest you continue in one of those many threads.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/670752-i-need-help/#findComment-8647706
Guest
