Hi, I'm currently running a 60mm triple 120 rad right now, and wondering if that plus a 60mm dual 120 rad would be enough to cool dual 780 plus the CPU.
I'm thinking maybe I'll add a single thick 120 on the back but i don't want to spend more if I don't have to
Intel 4770k : 4.6Ghz @1.285v | Asus Maximum VI Extreme | Asus GTX780 DCUii OC | Corsair Vengeance Pro 16 GB @2400mhz| Corsair AX1200i |
Samsung 840 Pro 256gb | Random mix match 3.5" hard drives |  Asus PB278q
Cooling : EK Supremacy Plexi/Nickle | Swiftech MCP655 Laing D5 | XSPC RX360 | EK D5 X-TOP CSQ |
https://linustechtips.com/topic/67061-do-i-need-more-radiator/
I say go 240mm per CPU (ESPECIALLY with your haswell, your haswell) and 120mm per GPU, so adding that 120mm would be good
even following your argumentation 360+2x120<3x120+2x120. Mathematics, dude.
No you will be fine. I am running a 4930k and dual 780s with a 360mm and 240mm rad, both 45 thick.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-917289
even following your argumentation 240+2x120<3x120+2x120. Mathematics, dude.
he's going to do 360 rad + a 120 rad <- he's adding just 1 120mm rad
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-917353
He has an 360mm rad so and 120+120+240 is 480 so yeah. I think you should learn how math works.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-917354
Yes 480mm rad-space should be ok. I would go for more rads because if you have dual 780 setup saving money is kind of a joke.
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-917363
ahm, dude, tripple 120 means 360 and dual 120 means 240.
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-917490
LOL yeh i guess so
haha yes you're correct
looks like i would be fine. okay. Time to watercool my GPUs I shoulda went for the 900D instead of NZXT 820 =/ that way i wouldn't be restricted with space but yeh
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-917716
LOL yeh i guess so
750D !
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-917802
It's that he wrote that he has a 360mm rad and the topics name is do i need more rads? Yes because he needs 480mm... We were talking that he should just get an 120mm extra.
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-917877
750D !
750D is the around the same size as the 820... plus I still need hard drive cages. Haven't got the feel to get a NAS yet though I really should.
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-918166
I'm sorry, i should've worded my question better. My original intention was to ask whether 360+240 was enough >_< my English is so darn bad.
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-918168
kk ^^
https://linustechtips.com/topic/67061-do-i-need-more-radiator/#findComment-918410
